View Single Post
Old 01-24-2019, 11:06 AM
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Thanks for this. This time last year there were 3 serious skid plate offerings after 8 years of 5th gen production. Suddenly, we are getting 3 more?
I think that what one expects with 6 vs 3 is a bit of a downward price adjustment.
If I were in your shoes, I would:
--try to reduce the prices, especially of easy skids like transmission skid.
--offer 3/16 steel we can drag over rocks plus aluminum and 1/8 steel that offers more coverage than stock. Only RCI offers affordable aluminum prices. Only BudBuild offers 1/8 steel which is what most need, actually.
--optimize front skid plate for minimum ground clearance loss under front edge
--ensure that front skid is even better supported than the good competition, for example, strengthen the crossmember were the middle supports of RCI or BudBuild plates attach.
--offer a tight fit rear differential skid that does not cost 300. 150 would be nice. It is not as essential, but needed to preserve drain plug and appearance.
--Offer rear LCA bracket skids that don't require drilling.
--Offer gas tank skid that has strong front and not just bottom and that attaches using the factory holes but not the gas tank strap holes!
--Offer a hitch skid plate/rear bumper skid plate that does not cost 160 like Skidmark and that does not interfere with the spare tire like the new one sold for 100 everywhere including 4WD parts.
Provide good info on the website about why the skids are better and provide pictures inside and out of each plus mounted.
Btw, I did not drill the hole for my pax side Shrock slider underneath the crossmemember and I have dragged that slider over rocks with no issues.
For sliders, Shrock offers superb powdercoating and cheap. That's about the one big difference between the models with sufficient strength. Also, most sliders are now pushing 1000 when finished, which is crazy.
@kjbenner
It is also an option not to get any sliders. They lose you a good 3" of ground clearance so unless you can drag them, you will be better off without when it comes to their primary function. 17" of stock rocker clearance is plenty even for normal difficult trails and where sliders are really required only steel will do. But it is true that side protection is also a thing especially in forested areas and tight washes in the desert. I don't know if aluminum can resist being pressed from the side as well as steel. But I think you do have a point when it comes to side protection.
