Can you take some center of wheel to bottom of fender measurements on all four corners? And hopefully someone with a stock pro could chime in with similar measurements. That's really a better way to judge what's going on
If you're not happy with the height you need to re spring it to do it right. Or wait till you have a good idea what you're going to add for additional weight and when to decide what to do.
