In the shop to get some work done even though it's about 30 degrees out. Luckily we've got heaters.
Apologies for the terrible lighting.
Even though the hood's up, that's not where I was working tonight... The battery did actually come back strong from the looks of it though. That's a first for me.
Tonight I installed the lift.
A simple setup, started in the back. The rears got some OME 891's I picked up used for this very type of build, along with extending the panhard bar to suit. The PO actually installed what appear to be KYB MonoMax shocks all around, the rears are actually a hair longer extended than stock shocks, so I was able to hook them back up, although they'll limit travel. I'll swap them eventually.
Then I quickly moved to the front. I left the shocks assembled with stock springs and just installed 3" bolt on top plate spacers. This isn't the route I'd recommend at all, but being that the shocks have relatively low miles and the springs aren't sagged out, I figured I'd get away with it temporarily at least.
And bada-bing bada-boom, just like that, a couple hours of work and under 150$ she sits 3" higher than when she rolled in. I know where some wheels are for cheap, but the only extra tires I have are just about bald terrains, so I'm not sure what the next move is as of now.
As a side note, this 4Runner actually spent some years on the east coast, and has a slight bit of rust, haven't run into anything major but I sympathize for you east coast guys, even this tiny bit of surface rust is kind of a pain when you're used to clean west coast chassis'
'97 3RZ 5 Speed "FrankenRunner" (
Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (
Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
