View Single Post
Old 02-11-2019, 11:09 AM
Outrider Outrider is offline
Outrider will become famous soon enough
I ran into an issue like this, years ago. I thought my engine was about to explode or implode. With some research on this forum, either by searching tons of posts, or by asking questions (I don't recall which method), I found out that it was the u-joints of my driveshaft.
The way I confirmed it was to crawl underneath, and grab the shaft near each u-joint and give it a good shake. If you feel any movement when you shake it, then it must be that u-joint. So, I suggest you try that.
I ended up repairing that $1,500 driveshaft for about $100, including the arbor press that I needed for the job, and kept mounted to my workbench, for future use on other things. If I recall, the new u-joints cost me $50-$60, but they have Zerk grease fittings on them, and they are removable and replaceable. If they should ever wear out, which they won't, because I grease them every year or so. It was a pretty involved job, requiring surgically cutting out the u-joints, and pressing in the new ones. I have tools and am handy with them, but it wasn't an easy or simple job.
The OEM design is really crappy, as the u-joints are neither maintainable or replaceable without surgery. It is either the result of beancounters telling Toyota engineers what to do, or it is planned obsolescence.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
