Real Name: Caleb
Real Name: Caleb
Mr. Nuts,
On one hand you'd be correct if we were in Europe - ECE regulation mandates that any HID or LED based headlight system be paired with a headlight washer too.
But DOT doesn't have such requirement. So if the light output is adequate, the turn signal is adequately far from the low beam light source (to create enough contrast) and the color of the sidemarker, turn signal, and low beam are within allowable spec...they will indeed pass state-side.
