Originally Posted by Bayou_Pro
Any concern with down travel and topping out the factory shocks, front or rear, with this setup?
No because TRD Pros use the same shock as the shock from the Bilstein 6112 kit. Just no adjustments.
Originally Posted by mqphung
How much did you lift your rear? I'm looking to add a similar setup to my 4runner and wanted to compare.
Wheeler T13 coil suppose to have a lift of 1.5 inches, I believe I got around 1.25 inches of lift.
Originally Posted by pDubs
I don't understand. You said you put 6112 on your TRD Pro which I assuming you took the OEM TRD Pro Bilsteins off. Were the 6112 not adjustable height?
Bayou_Pro and Akkording answered that question. Thank you.
