Originally Posted by Formidable
............SLOWING the vehicle down from speed...........
.....The reason people upgrade is to slow the vehicle down from speed...
.....Obviously, your ability to slow the vehicle down has a huge impact on where your brake zone is and resultant entrance speed into any turn regardless if you are on or off the track......
.....progressive feel of a bigger brake system and it’s effects on SLOWING the vehicle can be appreciated on the road... especially when the rig is fitted with trail armor, gear, and towing a 4K lb trailer......
......It’s not to improve stopping under emergency conditions. Its not for heat dissipation either. Again, it’s to slow the vehicle down from speed. Larger rotors, bigger calipers, bigger pads, more pistons, translates to improvement in braking performance period.
Your words here give the impression that you will stop faster with bigger brakes on some hypothetical corner and that's why people upgrade. Am I wrong?
I am saying that they wont stop your car faster due to every single reason I've already mentioned. Summary: Effectively if you don't do it for heat dissipation then you are doing it for looks and pedal
feel. Simple as that.
