Real Name: Mark
Real Name: Mark
I've wanted beadlocks for years don't need them can't justify the cost, have run at 15 psi a bunch yet to pop a bead can happen though.
I would be skeptical of a $1100 set, the ones I've priced like Brian posted the one's Rock Racers use are $700 and up each, steel are cheaper.
I tried the balancing beads 10-12 yrs ago running the highways alot, beads didn't last as long as the tires did. Swapping back to weights requires breaking tire down and getting all them damn beads out. Tire shop cussed me a bunch won't use again.
I dig the look, you have the money go for it sets off the look for sure.
