Originally Posted by eimkeith
are you sure it was a 7.5?
(wheel width is measured inside the wheel, bead seat to bead seat, whereas backspace is measured to the outside of the outermost lip.. - LOTS of confusion on the internet about this, and lots of skewed data because of it.)
EDIT: actually, there is a very good illustration of this on this very forum: Wheel backspacing and offset defined: (ignore everything after the first post on that thread; the first post is correct.)
Yea a guy I know who moved from MN to CO and asked me if I wanted it. Off a 2014 trail pro. 17x7.5 stamped right on it. I looked up the wheel someplace and it has the same 15 mm offset.
The link I posted in the original post is a great tool. I understand all the measurements but it does get confusing. I can see how people get confused.
I used the OEM wheel specs to compare with that tool. 16x7 15 mm offset.
The steel spare is only 11 mm closer to the UCA but that is enough to rub. Looks like it only works to be 3 mm closer than stock wheels. Sure you could go much further out but then your going to rub fender. Seems like you want to keep as tight as possible to the UCA without rubber for best stuffing.
