Originally Posted by eimkeith
I was thinking about all of this last night; using that calculator, wouldn't it be more useful to consider offset than BS? The important clearance is the tire (for truck purposes tire is much wider than the wheel, after all) and the wheel offset is what determines the centerline of the tire relative to the hub face, fender, suspension, etc...
Wheel bead wall thickness and its implications for BS doesn't affect the tire clearance.. particularly when comparing a theoretical tire/wheel setup with a known one?
This is EXACTLY why I argue that offset is the key factor in determining UCA clearance, not backspace. I’m sure someone will chime in soon telling me why I’m wrong...
sleepydad
You may also want to consider DOT compliant beadlocks, like Hutchinson’s Rock Monster Wheels - they are pretty badass!
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (
thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
