Originally Posted by Battle Born Offroad
These were designed specifically for Toyota platforms and have been mounted to FJ, Tacoma, Land Cruiser, 4Runners, etc without issue. I wouldnt take those liberties with the math, figure them as what they are, 16x8 0 Offset, 4.5BS. We have 27 sets with not one of our customers having a fit problem. Check Method's gallery for more images.
I did look at the method gallery for Toyota
Toyota Wheels
there are no shots of any 3rd gens running these wheels or any method wheels. so pretty sure they are targeting newer platforms not 3rd gens at all.
if you know for sure the 16x8 or 17x8.5 will work without spacers and no rubbing I will order a set. I'm probably heading the level 8 path because they make a -6mm offset in the same size that should work better than the methods.
if the answer is yes those will work yes we will return them if they don't then again I'm in, but my experience is once the wheel is mounted to a tire it's not returnable.
