Originally Posted by YodaOne
Yes, mine does have a distributor. I forgot to mention that was one of the things that are new, the previous owner had it replaced! It's OEM and the spark plugs are too! I've seen a lot of posts about not using OEM to insist on it no matter how much my boyfriend protests.
I didn't realize you had a distributor. I would go ahead and replace the distributor cap. Wouldn't worry about oem for that part either, it's not a mechanical part. Pick one up at any local parts store, swap it over and see if that helps. If it doesn't, just return it. Just the cap, mind you. But take the cap off and inspect the gap of the contacts and make sure no moisture has made its way in there.
