Originally Posted by alia176
Forgive my newb questions but what is the reason for having marks at 1,2,3 quart line? Why not have a gallon jug full of clean fluid then keep swapping fluid one gallon jug at a time until three jugs of fresh new ATF went through the system? Three jugs x 4 quart per jug = 12 quarts.
Hey bud,
its to measure exactly what you take out so you can exactly put the same amount in. 1,2,3 quarts is the lines, every time you take some out, it could be 2.2 quarts if you dont turn off the car in time. all you have to do is pour the same amount in the second jug, lining up the lines. You only use 2 jugs for this whole process, there is the dirty jug, and the clean jug.
