Originally Posted by LittleCaesar
Maybe a fuel pump? Also check grounds and for vacuum leaks.
The EFI fuse, if it has continuity, will just give you a beep from your DVM, stating that there is no break. Just pop off the top cover for a close inspection.
Thanks for the input.
I’ve checked for vacuum leaks, but I’ll keep an eye out. Where would be the grounds I’m looking for?
The EFI fuse I got 93ohms, not beeping and showing continuity. I’m going to check when it’s cold/sitting all day to see if there’s any difference. But I may swap one from the auto parts store just to check as that would be a real easy solution.
