Originally Posted by KNorm92
They can be used with a hi-lift jack but repeated use is not recommended as aluminum is not as rigid as steel and will flex. Yes - they are more running board-esque but like I said, not a boat load of trails to go nuts on here. Main function is a step and the added protection is a major plus.
I emailed them about the hi lift and they recommend not using them for that.
2018 sr5P XP Predator. Needed that 3rd row. TRD Pro susp, Toytec trd pro 2inch lift (HD springs), Gobi stealth, Falken at3w 285s, Trd and rci alum skids, Arb breather, Upper grill light source lightbar, slee sliders, wilco high clearance, arb awning, pedal commander, treaty offroad recovery points, alpha rex pro headlights, trd intake/exhaust, goal zero solar setup, greenlane offroad bumper, warn winch. C4 rear bumper coming...
