View Single Post
Old 03-02-2019, 12:54 PM
JB_RVA JB_RVA is offline
JB_RVA is on a distinguished road
2010 4runner sunroof drainage flixed
After much, much wasted time I was able to fix this today...with the help of another post on here. I took some photos to help illustrate. My issue was the water was not draining completely and splashing into the passenger area. Easy way to test is pour a few ounces of water on the passenger and driver side holes. If it does not drain right away there is likely a blockage at the FILTER.
String trimmer line will NOT solve this. You must remove the molding at the door base and to the left the emergency brake pedal. Use a plastic pry bar on the floor base plate and locate the 'bump" on your floor board that is holding the other trim piece in. Behind that you'll find some electronics. CAREFULLY pop off the blue pieces and use a 10mm socket to remove the white harness. This will allow you to remove the drain tube. Take a pair or pliers and lift up on the tube to unseat it from the hole. At the bottom of the tube check to see if the filter is clogged. Both of mine were and once I cleared them water instantly drained from the sunroof.
Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-27-29-0006-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-29-24-0005-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-29-47-0004-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-30-05-0003-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-30-32-0002-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-30-51-0001-jpg  Sunroof leak = Drains clogged. Help pleaee-2019-03-02_11-31-08-0000-jpg
JB_RVA is offline   Reply With QuoteReply With Quote
