Originally Posted by alumarine
The difference between the high and low marks on the dipstick is approximately 1 quart. How much do you have to add?
By the sounds of it you're down 1/2 a quart after a few thousand miles.
Nothing wrong with that. Even 1 quart wouldn't be the end of the world.
OK - in my other car the dots represent two quarts. So, good to know.
What I'm trying to assess is if I can lose that much oil from valve cover leaks or if I should be exploring other possibilities, namely because the valve cover fix is reasonably involved and if there's something I should do "while I'm in there" I appreciate the heads up.
