I can't see how this would be bad steering rack bushings? From what I have read and watched on YouTube it seems a tie-rod adjustment issue. When others adjust those the problem is corrected. Can anyone explain how the steering bushings would cause this? I'd think they would manifest as sloppy steering.
To be clear the truck drives pretty straight, but it's been sitting in the drive way for two weeks so I can't recall if it pulls or not, I don't believe it does.
Has anyone encountered this and resolved it?
Yes if I find a fix I'll do an update.
Hugh
Originally Posted by 4RunnerAquasport
Mine has done this twice after hitting the trails. My Alignment tech is very good and says it was not out of spec either time. Steering wheel was off between 10 and 11 o'clock to the passenger side the first time, then about the same to the drivers side the second time. We're thinking the bushings in the steering rack need replaced. Unfortunately not an easy fix, so I'm leaving it alone for the time being until I have the time to do it.
Post an update if you find a solution.
Good luck!
