View Single Post
Old 03-06-2019, 02:39 PM
JONBOY345 JONBOY345 is offline
JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about JONBOY345 has a spectacular aura about
4cyl Turbo-diesel with gobs of torque.
Imagine a fully built 4R that would be able to get 25ish MPG... (Assuming stock it's good for 35ish mpg).
Range would be significantly improved (that 5 gallons you're carrying as backup gets you much farther than the puny V6 would), huge low-end torque for towing/hauling/carrying around armor and gear, and dat sweet turbo whistle.
If not that, then not the motor and transmission out of the Taco. That thing is anemic at best. Would consider a 6th gen with a V8, buy on release a 4cyl turbo diesel. Hard no on the V6 out of the taco. I'll stick with my 4th gen.
'09 V8 Limited | Dobinsons Lift | Front: 3" - C59-302 + GS59-220 | Rear: 2.5" - C59-675V + GS59-701 | Tires | Ridge Grappler 275/65/18XL | Wheels | Method Standard Machined Finish 18x9 -12 offset | SPC UCAs | DT Long Tubes | GSport 2.5" Cats | DT Y-Pipe | Magnaflow Cat Back | 2.5" Vibrant Ultra Quiet Resonator
JONBOY345 is offline   Reply With QuoteReply With Quote
