View Single Post
Old 03-07-2019, 01:55 PM
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
Originally Posted by jeredcollins View Post
Gents pulled the trigger finally after 15 months of deliberating went with this lift. Wheelers Offroad has phenomenal customer service as well.
Front:
Tundra TRD Progressive Coils (2" lift)
Tundra 5100 Bilsteins
10mm Trim (.5" lift)
Rear:
OME 890 springs (3" lift)
I'm trying for around 2.5" up front and 3" in the rear for a slight rake. Does anyone have anyone ran this exact setup before? Are my numbers correct?
Last but not least I have the OEM trail rims and would like to run a 285/70R17. Will I need to get wheel spacers to run this setup?
I've been running this setup for years. My measurements are in a previous thread I started over 3 years ago. 3" in the back at least 2.5 in the front. No trim packers. The rake doesn't bother me. Really don't notice it. When you get some passengers in the back it levels out instead of sagging so that's a plus.
I'm running 275 70 17s and I don't rub. I tried spacers and did rub. Spacers make it worse. I finally got SCS Ray 10s which about perfectly balanced the backspacing to eliminate rubbing. Can't comment on rubbing with OEM UCAs with that size tire. I would think you would rub. A well setup alignment with LR UCAs and proper rim backspacing all help.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
