Here's another couple rules that I have found a little hard to follow but generally try to adhere to:
--when solo in remote areas drive a little slower than necessary;
--take breaks often.
The latter will minimize the times you get distracted, which you will if you spend enough time behind the wheel, while the former will help ensure that the rocky step or whatever else you failed to notice because you have been on smooth dirt for a while is nothing more than a rough bump. Having good armor helps with this, too.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
