Originally Posted by utahman11
I have a question on the Hellas, I'd like to connect them up to the OEM fog light connectors, is this feasible? Are there any electrical issues with using that OEM connection for those brighter lights? Also, I know that on the 4th gens, it would switch off the fogs if you had your brights on, and you couldn't run them independent of the headlights; is that also the case with the 3rd gen? I did the mod on my 4th gen to allow them to run independent of the headlights, is there a similar mod out there for the 3rd gens?
The Hellas use the exact same bulb as the factory fogs (assuming you use 55W H3's) - so there shouldn't be an issue there. I run Rigid D2 DOT beam pattern fogs on an aftermarket bumper - just change over the connector and you'll be fine. They do switch off with the high beams, that is a DOT requirement. I have the notes on my hard-copy wiring manual (not with me at the moment) for changing them to be switchable either constant or with the parking lights (what I would do). It is just connecting one wire to a different location...
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
