Originally Posted by dannyg
So I did the test and the MOTOR was definitely NOT running.
I ordered a replacement from eBay. It arrived Tuesday.
I just took a look to see about replacing the motor WITHOUT removing the whole assembly, disconnecting the brake lines etc., like JURONIN mentioned.
I don't see how you could possibly reach both screws holding the motor with it still attached to the vehicle??
Anyway, this video shows exactly what needs to be done (thanks JURONIN!):
YouTube
Seems pretty straight forward, just remove the unit, replace the motor, re-install. I'll just need to bleed the brakes once it's re-installed.
Great! I can knock it out this Saturday.
..... BUT I noticed signs of a leak, please see pics.
The leak appears to be on the OPPOSITE SIDE of the accumulator, around the bottom of the black box.
So, now I am stuck again because I don't know what is leaking/what other part(s) I need.
Any ideas?
(Also thanks for the heads up on the fuse! Will keep that in mind).
Thanks for the youtube link,
if your motor is toast, it was likely caused by a leaking accumulator, so changing just the motor alone, would be postponing the evil day, i think buying a complete used unit will be a better option, and keep your failed unit for spares/back up.
btw, did you check the 40amp fuse, that powers the motor to be sure its not shorted out??
2005 v6, galactic grey 4wd auto :
pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......
sold
2004 rav4 titanuim silver 4wd auto :
pionneer avhx 5500bt hu, pyle reverse cam
