Originally Posted by Mtoyotaownr
Thanks Backoff!
Just to clarify, you are saying to go with a smaller lifted coil. Like a 1.5” or 1.25”
Is that correct?
I don’t have any bumpers, winches nor plan on installing those items.
If I install lifted coils, do I need extended brake lines for the front or rear or both?
Thanks for the information.
Again some personal preference.
Do you like a front lowered/raked stance? Or do you like it more level?
1.25" OME coils with the 10mm trim packer might be a more level option. For the rear.
Should not 'need' ext brake lines.
May consider...
Front sway-bar relocate kit... bar may hit the front coils after lift.
Rear 2nd gen T4R sway bar links... 1 inch longer/ budget mode... or you can get the $150 Superdooper links.
