Originally Posted by nobb
How are you using the access port to loosen the brake shoes? The adjuster only goes one way. Due to the mechanism, it would take quite a bit of force to get the adjuster wheel to turn the opposite direction.
From Mtbtim above: When I can't seem to get a drum off, I take out the rubber plug on the backing plate, use a small screwdriver to push the self-adjuster plate away from the star wheel adjuster and then turn the star wheel a bunch of times to back off the shoes from the drum. After that, the drum comes off easily.
