I just did this yesterday and was shocked/thrilled about how quick/easy it was. Sure I had to make a trip to the HW store to get some parts for the job but total cost was <$10 and it didn't take much time to find everything.
I swapped in 8 fresh qts of WS and a tube of shudder fix. The old fluid was black (190K miles) and as of the last 2qt flush I did the fluid had returned to a dark red even though 4 qts of the original were still in the system.
Not only was it a quick/clean/easy way to do this without even having to get on the ground my truck was shifting/driving MUCH better right away. Before the ATF swap I'd get the "shudder" after every gear change. Upon the first test drive it only did it around 40mph. The more I drove it the better it got. I only put about 15 miles on the thing before the shudder was completely gone. I can imagine it'll get even better with time.
What a fantastic resource this page and its members are!
Originally Posted by UrbanRunner651
Since the fluid is not returning to the system the same time it is exiting, would this not potentially introduce air into the system and result in improper levels?
When I did this yesterday and was filling the system from a funnel I had hanging above the engine bay I thought the same as you about introducing air but as I poured in the ATF I could see it was forcing the air back up out of the funnel so Im positive it was all purged out.
