Adjust the fluid pressure by changing the A or B length.
1. Low pressure - Lengthen A, B
2. High pressure- Shorten A, B
HINT: Fluid pressure change for one turn of the lock nut is 100 kPa (1.0 kgf/cm2, 14 psi) and fluid pressure change for 1 mm (0.04 inch) sliding of the adjust bolt within the long hole position is 40 kPa (0.4 kgf/cm2, 6 psi).
Initial set length (Unladen): 222.5 mm (8.760 inch)
