Just wanted to share my thoughts on the newer Victory 4x4 Molle Panel. Ordered and received the panel in less then a week so it was already off to a good start. I installed it yesterday and it was an easy install and fit perfectly, and followed the contour of the opening. Only issue I ran into was the head was made imperfect on one of the supplied Allen bolts and the wrench would not fit in the head. I was able to get a star bit in there and was able to tighten up fairly tight. I doubt it will be an issue. Not thier issue but the manufacturer. It came with flanged nuts with the teeth on the back. I'm hopeful that they wont back off with vibrations. I would have preferred a washer and a nylock nut myself but that being very critical. Only other critique I would make is the white nylon spacers stand out like a sore thumb. I was going to just paint them but wasn't sure if it would stick so I just simply wrapped them with electrical tape. All in all in very happy with it and saved some money over some of the other panels. Would totally recommend this panel!!!
Paul
2016
TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
