Originally Posted by Terminator03
Yes, but your better off not ordering the complete set of 4 like that because, as mentioned, the rear rotor has a different bore that causes problems for some. When I ordered mine, I went for the z34 towing/heavy duty pads, but everything else is the same. I ordered the pad and rotor kit for the 2010 front, pad and rotor kit for 2004, then ordered the calipers separately for 2010. The pads for the rear are all the same, as is the rotor thickness and diameter, so the 5th gen caliper bolts right up. The 5th gen rear calipers just had a slightly larger piston or something, so I went with those and then 4th gen rotors and pads. Very happy with the performance so far, and they look awesome! Just hope they last...
2010 Front Pads, Rotors, and Calipers (Z36 Extreme) -
RockAuto:
https://www.rockauto.com/?tab=search...rtnum=KC587336 $435.79, (refundable core of $96)
Amazon:
https://www.amazon.com/dp/B079396VZL/?tag=powsto07-20 $392.99
2004 Rear Pads and Rotors (Z36 Extreme) -
RockAuto:
https://www.rockauto.com/en/moreinfo.php?pk=3802839 $150.79
Amazon:
https://www.amazon.com/dp/B005UB5O46/?tag=powsto07-20 $164.99
2010 Rear Calipers -
RockAuto:
https://www.rockauto.com/en/moreinfo.php?pk=4491219 $157.58, (refundable core of $60)
Amazon:
https://www.amazon.com/dp/B00DGRQYMC/?tag=powsto07-20 $156.21
SS Brake Lines -
Goodridge 2-21186 G-Stop Brake Lines | Autoplicity $149.21
Amazon:
https://www.amazon.com/Goodridge-2-2...gateway&sr=8-1 $154.75
Parts cost after core refunds: $722.37
If someone can confirm the parts above I’d greatly appreciate it! Also, as I understand it this will work on my 2003 SR5 V8 with 17” wheels as long as I cut/bend the brake shields.
