Originally Posted by titan34
Thanks for the advice. Will the 5100 fit a 2wd? I heard they only 4wd and only the 4600 does.
The 2WD and 4WD front suspension geometry is the same. 5100's will bolt right on. Springs designed for a 4WD will lift the front end more than expected (the 2WD is much lighter up front).
If you end up doing 5100's, keep the stock/current springs up front and lift using the spring perch adjustment.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
