Originally Posted by DeserT4R
I’ve read that entire Dobinsons post and Speedy is correct. The coil they bailed on was the 15” or 2” over Pro for the reasons you are referring to. They did stick with the 14” or 1” over Pro version but it maintained the #520 not the #600 of the 6112 coil. It should be noted that in my research that Eibach does make the 6112 #600 coil but they just don’t sell them on their own.
Ok, that makes sense. I combed through the thread myself (a couple times) and missed that is was a 15" coil with the stock 520lb spring rate.
I'm curious if the Eibach/Billy 14" coil with the 600lb spring rate is worse for the strut than the Dobinsons 14" coil with 520lb spring rate. You are getting an inch more lift with the 600lb coil!
08' Limited V8 (2020-Current)
17' TRD Pro (Sold: 2017-2020) -
Update/Mod/Build/Adventure Thread
08' Urban Runner (Sold: 2010-2017)
