Originally Posted by Bad Luck
For what it's worth, I replaced the radiator, timing belt, water pump, and thermostat when I first purchased my runner a couple months ago. The gates thermostat that came with my kit ran the vehicle up to 205 before I got concerned and switched it to the OEM thermostat. Both thermostats had the jiggle valves at 6 (completely opposite of every gm that I've worked on with a jiggle valve) and thoroughly burped the system with a spill free funnel. I used toyota red coolant as well. now my coolant temps haven't exceeded 192 degrees. I'm monitoring temperature via ultraguage.
So, the OEM thermostat opened earlier? I might have to switch out the thermostat if thats the case. I haven't ever tried to read the temps on mine. What are you using to do this?
