Originally Posted by ddicosmo
Thanks everyone for the help. I think I may have found the issue. You are correct about the EVAP system. I re-checked my gas cap this morning and noticed that it comes off really easy. When I put the cap on and it clicks a few times, it takes very little pressure turning it counter clockwise for it to come off. Looks like the seal on the gas cap is worn or defective. I will order a new gas cap at the dealer and hopefully, that will fix the issue (fingers crossed). After I put the new gas cap on, should I try and reset the codes (ie. disconnect battery method) or should I drive and see if they clear up by themselves? Thanks,
Dave.
Just drive it a few days and see if they go off, if not then do the battery disconnect and hopefully this solves the issue.
