Originally Posted by Redsoxx1918
Lol...so what you’re saying is that you haven’t used a sprint booster and that you have no experience to base your assumptions on. I know perfectly well what I’m talking about and I fully understand drive by wire systems.
You can repeat that all you want, and maybe you even believe it, but when you follow it up with
You can not duplicate what the sprint booster or pedal commander does by simply flooring the vehicle.
...anyone who actually understands DBW knows you're full of it. Your pedal outputs a voltage when you press it. Sprint Booster takes that voltage and amplifies it, but only to the max voltage, so your pedal essentially becomes useless beyond the upper quarter/half etc depending on the setting. This is exactly the same as flooring the pedal.
Flooring pedal = max voltage (assuming electrical resistance is set up that way)
Sprint booster + half pedal = max voltage
Sprint booster+ flooring = still max voltage
This is basic, basic stuff. Not even controversial. What's your sticking point? Did you buy one without realizing that it's just increasing voltage based on a set ratio? What correlation are you failing to comprehend between the voltage output when you press the pedal and the increased voltage put out by SB, which essentially decreases your effective pedal range, AKA "floors" your pedal sooner??
Try one first before you give a review.
Ever tried hexagonal water? It's amazing, cures cancer, AIDS and retardation with just one sip. You can make your own (invisible changes, of course) for only $399. Oh, you don't believe me? Well, if you've never tried it you have no experience to base your assumptions on, so better buy this right up! -
https://www.amazon.com/Mineralized-H.../dp/B0044VEBF6
Then we'll talk.
