View Single Post
Old 04-19-2019, 07:36 AM
dogtail's Avatar
dogtail dogtail is offline
Real Name: Keith
dogtail has a spectacular aura about dogtail has a spectacular aura about
dogtail's Avatar
Real Name: Keith
Originally Posted by arbys View Post
How did everyone deal with getting the nut or bolt off the upper right of the flange as as you look from the bottom? It's so tight in there that I have ruined the nut and can't get it off.
If you are junking your front cat, you can cut it off with a SawsAll near the studs. And any nuts you wrecked, use a Map Gas bottle torch heat the stud/nut up repeatedly if needed and wiggle it back and forth til you can unscrew it with Visegrips or whatever will grap it, stud and all, or if stud stays on, you can keep it on, but nice if you can get it out. Autozone sells a stud kit for these with brass nuts thats wont rust up....but the stud kit has different threads than the original, so you can't just use the nuts.
Aftermarket cat converter advice needed-img_3029-jpg
*1999 3.4L, 4wd/5spd, swapped motor and trans, heavy use DD, seasonal rust proofing using WD-40 only
*2000 3.4L, 4wd/5spd, parts rig, picking the carcass
dogtail is offline   Reply With QuoteReply With Quote
