Originally Posted by Rpreme
Sorry for opening an old thread. I felt it was appropriate to post it here.
Since operating charging voltage is 13.7v - 14.0v at idle, my scangauge II is reading 13.5v- 13.6v as of late at idle and under loading.
Is it time to replace my battery?
BTW, the scangauge II is an awesome gauge.
Trick question, huh? Charging voltage has little to do with battery health, except that poor charging performance will likely kill a battery eventually.
If you want to check battery health, charge it up and find someone to do a load test. If you want to check your charging system, go here:
http://www.teamtoyota4x4.org/archivi.../chasy/ovi.pdf
Idle voltages are not that important. 2000 RPM values are what you want to look at. Always worth cleaning terminals and grounds and inspecting cables.
My Backyard Frame Swap
