Originally Posted by Tuby27
2004 sr5 4x4 daily driver and no extra body weight. Thinking of going with 5100 around and wheelers springs both front and back, no spacers. I think the wheelers are comparable to the eibachs 620. I understand these have a stiffer ride than stock and I don’t mind since I may use it for trails and camping. Anyone have this set up? What is the lift gain, my research is between 1-2” front and back. Just hoping to get a little extra lift but no higher than 2.5”. Please advise if I need to set the front at a different perch to level/slight rake with the rear springs.
Thanks
I would go with the Eibach spring, you will want the extra lift to level it out, leave the the 5100 at 0. Wheelers springs will keep the factory rake, about an inch front to back.
