Originally Posted by mack10
It definitely was, the sliders were rusted pretty badly. However the cylinders still worked after I removed the pads and threw in some plywood so they wouldn't pop out. Enough to crush the plywood after a couple pumps. Instead of taking it all apart I cleaned up the pins lubed everything and put it back together. Still have the same problem though so I'll probably get a set of the NAPA calipers. There's also quite a big difference in pad material left vs right, even if the caliper was working fine (now) would the difference in the pad thickness still cause this? I drove it around quite a bit and tried to bed in the left side but it didn't seem to improve... If I get new calipers I'll have to get pads anyway.
The difference in pad thickness is a result of the caliper dragging. Those pin sliders really don't restrict anything. Not like my old Exploder. Get some calipers and pads and go from there and get out from underneath that truck. I'm sure you have better things to do.
