Originally Posted by 4runnerWiniarski23
Tried to head to autozone to get a replacement hardlines they didn't have much choices.
Going to go to advanced next
Are these anything special? M12 or m14 threaded flare ends?
Thanks
You can only get these tubes from Toyota. You might be able to fabricate them, but it's all metric and might have weird ends on them. The easiest way to get fittings off when you are replacing the line anyway is to cut the line off and use a socket on the fitting.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
