Originally Posted by Seasparrow
Question to SarasGen34Runner, Is the screen in the bottom of the reservoir? Do you remove it or clean it in place, Thanks for the tip on the screen.
The screen is inside the reservoir and not removable, so you remove the reservoir and back-flush it. I used mineral spirits, capped both hose fittings, and shook the thing vigorously...took a few iterations with fresh mineral spirits before the screen was clean. I then rinsed it with fresh transmission fluid, just a few ounces and rotated the reservoir to slosh it over the entire interior.
