View Single Post
Old 04-25-2019, 11:20 PM
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Oil Change #2 - 195,763 Miles
With the current access to the oil filter, I decided to use this time to change the oil for the second time. I noticed that King only provided 3 bolts and 3 washers for the installation. Each coil-over needs three for the top mount, so King will have those here tomorrow... Very fast support.
My first three oil changes will see Seafoam treatment.
I put about 6 ounces in yesterday (about an ounce per quart), and let it idle for about 15 minutes. I ran it again today for about 20 minutes, and then let it drain. I like draining oil when it's hot, and now with the Fumoto valve, this is so easy to do.
I put the rest of the Seafoam in the gas tank...
I used this with a ratchet and extension to loosen the oil filter.
I'm still not that good with a clean removal. It was messier than what I had hoped. Maybe I'll improve next time. I let it drain for a few hours while I attended two meetings for my employer. I got out this much out.
UPS arrived with the oil filter, actually five of them. Toyota OEM and these came to about 5 bucks each. I saw a little better deal for 10, but that was not Amazon Prime delivery, and I wanted to do the oil change today.
About 5 1/2 quarts filled her up. I then used a power washer with some Simple Green to clean the spilled oil.
Tomorrow (Friday) I get the hardware from King and also five Gorilla wheel locks. The SPC UCAs and King coil-overs should get installed this weekend.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
