Originally Posted by gamefreakgc
Most companies only sell OEM reman'd calipers. So if you order Powerstop, Calihan, NAPA, etc. they are all the same OEM Toyota calipers, very few companies have reverse engineered a caliper and made their own, I'm yet to see one for our 4Runners. Where it differs between companies is the quality of the aftermarket seals and components installed in them.
I'm going on 4 years with my Powerstop calipers with no issue.
@ 4Runner4Leon
try re-bedding your brakes. When I installed my rotors, I went on some "spirited" drives and heated up my brakes big time. I thought I had warped them but realize that the pad material wasn't evenly distributed on the rotor, I could see it. I did another brake bedding proceduce and the wobble went away.
If that doesn't do it, just have them turned at a machine shop for cheap.
Thanks, I'll give that a shot. I bedded them in per the instructions, and they were fine for a while. Just recently I noticed the chatter again. I'll try the procedure again.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
