Real Name: Chris
Real Name: Chris
Originally Posted by max rockatansky
21" front
22" rear
even on both sides, luckily I didn't get the "lean" some people with KDSS do.
You got exactly 1" lift up front. Strange since the pro suspension should lift .75 without anything extra at all. Had you not used that top hat spacer, you would not have gained any lift at all. Stock is 22 in the back, 20 up front. What size tires are you running?
