Got the rear and center diff fluid change knocked out. Ended up using the Lucas Oil Synthetic 75w-90 fluid for both. Also picked up a set of crush washers/gaskets to service both axles and the center diff. So far there are no leaks and everything seemed identical to stock. I also noticed that the gear oil that came out seemed to be somewhat new still, this was surprising because nothing else on the vehicle has been maintained by the PO. No sign of water intrusion on the rear axle either. All good stuff.
The washer set can be found here
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
