Real Name: KE0OIC
Real Name: KE0OIC
Is the light bar hooked up via a relay or just via the switch? If a relay, what about making the relay circuit switched by the ignition? So when you turn the truck off, everything is off? You could also add a relay to do the same thing easily enough if the bar is just running through the switch.....
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
