View Single Post
Old 06-22-2008, 02:48 PM
drmorbius's Avatar
drmorbius drmorbius is offline
drmorbius is on a distinguished road
drmorbius's Avatar
Originally posted by gkatmar
Well I removed the JbL sub and there are 4 wires. A green, yellow, black, and orange. I'm not sure which ones are positive and negative and left and right?
This is a dual voice coil subwoofer. Use an ohmeter to find continuity for each pair of wires. To find out which is positive take a 9 volt battery and using clip leads touch the battery to each voice coil while watching the speaker cone. It will either move in or out each time you touch it with the battery. Positive is when the cone moves toward you. Do this again for the other coil so they will be in phase when you hook them up. By the way this is a mono set up intended for two amps which use the same signal.
Larry
"Monsters From the Id"
2004 SR5 V6 Titanium Metallic/Stone, Auto Dimming Compass Mirror, Valor Tip, Overhead Console W/HomeLink, Cargo Net, Michelin Cross Terrains, Added JBL Synthesis 10 speaker system 6/08, USA Spec PA-15 TOY Ipod Interface, Drivers Side Overhead Handle, Valvoline Synpower 5W-30, Mobil 1 75W-90, LEDs
drmorbius is offline   Reply With QuoteReply With Quote
