Originally Posted by overlandout
You are just going to use 4th gen parts right? If using 5th gen make sure you stick with 4th gen rotors. The hub diameter is different and will give you problems.
Sent from my SM-G950U using Tapatalk
Just clarifying this statement. Only the 5th gen rear rotors cause issue. The fronts work fine.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs |
5th Gen Brakes | Everything else is in the
Build Thread
