View Single Post
Old 05-07-2019, 07:14 PM
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by ToyoTex View Post
Sorry about the delay in response!
He has the LT-E and didn't air down far enough :-)
Thanks!
Originally Posted by Swipter View Post
So that's an issue that can happen with any tire, regardless of tread plies?
Yes.
Generally, P-metric tires are not part of offroad discussions and for LT metric it goes like this:
Air down offroad for:
1/ Comfort. Normally 20sh should ok.
2/ Traction. I am sure there is a thread about what psi for what conditions, it also depends on wheels, loads, etc.
3/ Prevent through-the-tread punctures like that.
As for P-metric tires, few of us do a lot of offroading on those and it is different as they are more likely to burst a sidewall when run at lower pressures. They also deflect plenty at 30-33 psi and so there is no need to air down for comfort or traction, except on deep, soft surfaces.
