Originally Posted by blackmax
Okay, purchased and installed a new Denso relay. It worked fine for a few days. Then.....same thing. No start. I've got this down to a science now though....just pop hood, wiggle and/or tap on relay.....restart. BUT, this has now happened multiple times ON the highway. Ridiculously dangerous.
So, any thoughts on what is causing this? The contacts seem good, but maybe I need to look closer.
You need to inspect the part that accepts the relay, those pins could be loose and not biting causing a poor connection. Youll have to pull the spade connector and give it a squeeze with some pliers to help make it bite
