Originally Posted by Bpzimm
Yeah this helps, thanks. My problem is I DID install the spacers on the upstream 02s at first bc they sent me 4, so maybe that threw everything out of wack?
YES, NEVER install spacers on the upstream sensors. They are air/fuel ratio sensors controlling how the engine runs and are not related to catalyst efficiency - they are located BEFORE the catalysts in the factory header. Any fault codes return with spacers only on the downstream? You might need to stack 2 or 3 on each side.
